VicarsLures
- Feb 26, 2005
- 5
I just purchased a 30 hp 1988 or 1989 yamaha. I have had many johnson in the past. It came with the controls. There are two plugs coming out of the shifter box.One has four wires. The other has three. Is this where the wire harness plugs into? Also, There is no gas hook-up, There is no hose running into the inlet inside the motor. Does this connect directly to the gas plug that will connect to the gas line from the tank. Thanks in advance. <br /><br />Carl
