Re: 1991 30 HP Yamaha Model #30ESRP
hello<br /> there is a vent that is normally plugged for draining and filling the gear case. there are some holes for water drains for the pump and exhaust cavity area. what does the oil smell like. here is where a picture could say a thousand words. most the time when GEAR case oil is draining from a water drain it indicates a bad drive shaft seal or a bad shift shaft seal. if its waste fuel oil it can indicate an excessivly rich fuel/air mix.
