Hello!<br /><br />Is there anything special to check on a Yamaha 60hp -86 engine?<br /><br />I'm planning to rebuild the carburators and changing impeller.<br /><br />Any short advice about removing the lower unit.<br />How will I disconnect the gearchanging linkage and<br />what's the thin hose that goes down to the lower unit parallell to linkage?<br /><br />I believe I should order a Clymer manual. It would make servicing easier!<br /><br />Best regards,<br />Robbi
