I have a Yamaha 2000 vmax 150 oxy66 that suffered a bearing failure on the 5th rod (at least its second from the bottom) at the crankshaft. A real meltdown! I paid the dealer to investigate and he stripped it down and showed me the parts. The boat is used for skiing and tubing. I live in Ontario Canada so only use the boat for 2-3 months in the summer. To date I've had zero trouble and always had dealers winterize the boat. I had one oil warning alarm light prior to failure and we immediately filled up the oil reserve which wasn't empty.<br /><br />I took the parts and remains off the dealer and am thinking about the best approach<br /><br />My question:<br />1) Is this common; it seems pretty early for this kind of failure after only 4 summers<br />2) The dealer says 5K to fix of which 80% is parts. Is that reasonable?<br />3) Is a remanufactured block a better bet than fixing the crank, the rod, etc plus new bearings, rings and gaskets?<br />4 A friend suggested the fix and sell approach on the principle of where there's fire there's likely more fire; any comments.<br />5) Is there much hope of joy from Yamaha<br /><br />Any thoughts welcome; Dave
