Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Yamaha 90 Oil Injection Failure
  • Yamaha 90 Oil Injection Failure
    I ran my 1993 Yamaha 90 today after about 3 months of storage. (Plenty of oil in the engine tank) The boat ran fine at high speed for a few minutes then the engine began to falter and died. My guages are very cloudy and hard to read so I don't know if any of the warning lights are working but I'm pretty sure it is not getting oil. (No Smoke) It will idle ok but after a few moments of mid speed it gets noisy. How can I check the oil flow? Since it still idles fine and runs for a few moments at higher speeds is there a chance I have not yet ruined this engine?
    Re: Yamaha 90 Oil Injection Failure
    hello did you bleed the system after storing it? have you ever cleaned the tank and tank filter? the only way to know is by dissasembly and inspection. overheat will cause the same symptoms. when was the last alarm circuit test done? the oil injection on a yamaha is about as bullet proof as you can make a piece of machinery,however it requires maint like everything else. and maint does not mean just add more oil.
    no tech questions by PM, they wont get answered.
    you have to be trusted by the people that you lie to .
    • #3
      No I did not bleed the system nor have I ever cleaned the tank. or filter. It's pumping great water preasure and does not feel hot to the touch and the heat alarm works good. Is there a hose that I can pull while at idle to see if oil is moving?
      • #4
        hello I suspect rather than a precision blend failure we are dealing with a customer neglect failure. much more common than pump failures.somewhere in your service manual there is an oil consumption test. all the tests require the engine to have a 50-1 premix while running the test. I cannot remember the output specs but you unplug the hose downstream of any inline check valves,if used, and run the engine at the specified RPM for the specified time and collect the oil. the details are in the manual. but remember he pre mix while doing it.
        • #5
          Running the motor on 50:1 fuel I have removed a few oil lines but NO oil is flowing anywhere. Can someone explain the theory of opperation. What drives the pump?
          • #6
            its gear driven from the crankshaft.
            • #7
              Time to purchase a workshop manual! Absolute must if you plan on doing your own maintenance.
              • #8
                Does the motor run properly on premix? If so it points to the oil pump not working... could be broken or just needs bleeding. After buying the manual as suggested, follow the bleed routine and do the test again. If still no oil flow it could be an airleak in the lines or a broken pump. I'm not an expert but had this problem a few years ago on a Yam 50 and it was because I hadn't bled the oiling system.
                TABS 580 Ocean Series - Sold!
                Yamaha F115 - Sold!
                Holden Rodeo LT crewcab ute - still going strong.
