My 1985 Yamaha will hardly crank when i try to start it. At first,I thought it was the battery . It had sat for a few weeks so I charged it fully ,tried again and result was the same. I tried turning the fly wheel . It was difficult but it turned. I removed the plugs and tried cranking it with the starter. It seemed to crank normally. When i put the plugs back in ,it hardly cranked.(not even 10 degrees on the flywheel) Then I tried a friend's battery to eliminate the posibility of my battery being no good . It hardly cranked. I also bypassed my battery selector switch and cleaned all connections even though they looked ok. At this point I am suspecting the starter. I purchased the Yamaha dealers manual but it give no checks for the starter. Is there any way to check it out ? Thanks for any help or ideas you might have.
