The other day I felt the water coming out of the pisser as I idled down a mile long lagoon. The water was very cool. Is this ok or should the steam be hot?
Luke warm but it depends on the surrounding water temperature and how hard you had been running. Get a water temperature meter and a water pressure meter. Less than $ 50 for both and definitely the best insurance I bought.
hello<br /> the tell tale water comes stright from the pump to the adaptor and out of the exhaust cover. it will be about the same temp as the sea. its not a temp indicator just allows the operator to see if the pump is pumping.<br /> good luck and keep posting
