Re: can someone look up some specs for me please? Yamaha 9.9
1991 yamaha 9.9 4-stroke. It started crapping out on me two days ago. I've been through the carb with a kit (carb was spotless inside) and the problem remains. Missing, backfiring through carb, running on one cylinder intermittently, bogging and stalling for a moment when acclerating and then when it catches up with itself, usually running on one cylinder. Plugs look OK, except one of them is usually wet (not the same one either). I don't have a service manual yet, and I am suspecting electrical, since every yamaha bike I ever owned or worked on had some kind of mysterious black box type of electrical failure at some point in its life, which often resulted in similar symptoms.
