I have a Kingfisher boat with Suzuki 40hp. The motor runs fine the water impeller works great. The problem is I wanted to ensure there was no water in the gear case I started pumping lube into the lower unit fluid is exiting from the prop area and other sections. The motor goes into gear fine so do I just need new seals or what?
