I recently purchased a 1994 30 ft Scarab Sport w/ twin 1994 Yamaha 225 hp saltwater series 76 degV outboards. Motors have approx 530 hrs each. Both motors generally run fine with the excption that the starboard motor has a tendency to run rough, bog and stall when accelerating from idle after the motor has been operating for a while. The motor can be made to run if the throttle is pushed all the way forward, it will hesitate slightly then accelerate. I have already checked & changed spark plugs, and both the onboard and remote fuel filters. I'm thinking my problem is with the carbs, maybe some fouling or a sticking float, but I wanted to get some opinions before I go any further. Additional note, the motor that is having this problem seems to be harder to prime than the other one, i.e. it is difficult to fill the onboard motor fuel filter bulb with gas completely by using the primer bulb?
