Hello, this is my first post and I've done a lot of reading of other posts to solve my problem, but still stumped. I have a 1987 dt200 that starts and idles fine. When I put it in gear it dies out. So from reading other similar posts, I took the advise and cleaned the carbs. They were very clean upon inspection, but took the floats and needles out of all 3 and ran some carb cleaner through them anyway. Reinstalled and problem persists. I could always keep the engine going under load if I hit the purge switch to shoot more gas in, which leads me to believe that it's running lean. So I backed off the screws a full turn on all three, did nothing, after another turn to make it richer, still same problem. What's confusing is that it runs great through the rpm range not in gear and IF I get it on plane it runs great. All fuel line and tank have been replaced. I have a fresh 40 gallons in there now with 2 cans of Sea Foam, so I'm stumped. If this helps, this problem started at the end of last season when it started getting cold. Any ideas? Is there a way to test the mechanical fuel pumps? It really seems like it's starving for fuel?
