On my yamaha 90 hp i have a strange part, its a bracket, bolted to the engine mount on the righthand outside just below the trim/tilt assembly.<br /><br />The part is a stainless steel bracket, 2mm thick an 30 mm long, with two holes, the free hole is pointing backwards.<br /><br /> What is it used for? Can I remove or will I need it for something? Did the previous owner attach it for some reason?
