Hi,<br />Im looking for the Torque settings for cylinder head of a 2003 150hp Yamaha 6 cylinder, 2 stroke outboard engine. If anyone has helpful information please post it. Thanks
I just rebuilt a 2001 VMAX 150 OX66. The Torque setting for that cylinder head, for the 8 x 60 mm bolts are. 1st 11 ft/lb then 22 ft/lb for the second time around. if you removed the water jacket the 6 x 30 mm bolts are 2.9 ft/lb then 5.8 ft/lb. I hope this helps! Good luck,
