I have a Suzuki DF250 (4 stroke) installed on a new 2004 Rinalli 21' boat I just bought. I thought I had a problem with the Seastar hydraulic steering, but after Rinalli changed the cylinder and switched to a helm unit that moves less fluid per revolution, the steering torque is still extremely high. Rinalli and I are both scratching our heads trying to solve this problem (great service from Rinalli). I'm using a Suzuki 16" wheel that is recommended for this engine. Rinalli tried three of the 16" Suzuki wheels and still could not eliminate the high steering torque. I'm beginning to believe this is a common problem with this engine on smaller boats that Suzuki has not owned up to. My guess is the high steering torque is created by either the prop diameter/design or the lower unit design or a combination of both. I would like to hear from boat owners that have single engine installations with the DF250 and have the same problem. I understand many of the DF250 installs require a bolt on torque tamer on the Skeg to solve this problem. However for me this is not what I call a real fix to the problem, but rather a band aid. You can e-mail me direct at ricjames@bellsouth.net
