pukeanddie
- May 9, 2004
- 4
I was trying to warm up my Suzuki df70 after winter storage so I could change the oil. The engine started up beautifully and ran at about 1000 rpms until it reached a certain temp and then dropped down to about 500. I assume this is normal. <br /><br />I let it idle for about 10 mins at 500 rpms until I noticed that the motor was still ejecting cold water and felt cold. In hopes of bringing the engine up to tempature more rapidly I increased the throttle back up just slightly so it was again running at about 1000 rpms. Water was still coming out of the telltale, but about a min or so later the temp alarm went off. I was Running the engine with muffs and the cavitation plate water intake was covered with duct tape. The whole time there was a steady stream of cold water coming from the telltale. To touch though, the engine was indeed very hot and I am confused how this could have happened. How could telltale water still be cold when the engine was so hot and why was it overheating?
