I recently bought a 1996 DT150, I had it installed by a dealer, the motor has a new cylinder so it was recomended to do a break in period. I ran the motor @ 2000RPM for about 15min and the high temp alarm began going off. I turned the motor off and checked the heads, they were hot, but could still touch and hold hand on them. the water coming out of the tale-tale stream was normal, and when i ran it at higher RPMs i got no alarms, or any alarms at idle. Any suggestions? Also the motor idles at 1000 RPM and shifts roughly into gear, im afraid of it damaging the lowere unit, the dealer checked it out and called it normal, but also noted that it may have not been coming out of high idle mode, but once checked, they still said it was OK. Thanks for any help.
