Yesterday, while fishing Chokoloskee, my 2001 DF70 stopped charging - 125 hours. It may not have been charging when I left the ramp. Dunno, but it cranked just fine. Anyway, after a few hours fishing and running live well the engine barely cranked. New battery, BTW. I put a voltmeter on the battery while running and it showed 11.4 volts. Of course, I turned off the live well and made sure there wasn't any other apparent battery drain.<br /><br />Next fishing hole, the engine wouldn't crank at all. Got it going with hand start. Didn't want to ruin a good day of fishing! It's not easy hand starting and I wouldn't recommend it as a backup.<br /><br />About the third fishing hole, had a real hard time getting the engine going again and if I went to idle for more than a second, it would die. Voltage was below 11. Time to head to the ramp!<br /><br />The 30 amp fuse on the starboard side of engine is fine. The "check engine" light and alarm didn't come on till it was too late.<br /><br />Regulator? Alternator? Where should I look for the obvious (inexpensive) before taking it to the shop? <br /><br />Thanks!<br /><br />-fred
