Re: Prop nut seemed to loosen up with cotter pin
hello<br /> could be. how tight was tight and how loose is loose. the torque is about 25 ft lbs up to 55-60.<br /> if it was not saeted all the way it will do that as well. are you using factory props and hardware or aftermarket stuff?<br /> good luck and keep posting
