Hello again.<br /><br />I have a question about the 703 control.<br />My control has the key slot then just below the key slot there is a lever and then below the lever is the kill button for the safty lanyard.I do not have the levers on the handle for the tilt.<br /><br />What is that lever between the key and kill button do. Every time I push it up I hear a click, and the click is comming from the solenoid that is hooked onto the lower carb.<br /><br />Is it the choke ?<br />And if it is the choke It is not openning my valves(butterfly) in the carbs. Also is it suppose to click where the solenoid is or is that a sign of a bad solenoid?<br /><br />thanks
