Please help. I am trying to repair a 1985 30 hp. Suzuki outboard which is sticking in reverse gear. The prop took a hit on a stump in reverse. Neutral to forward is fine. Lower unit gears look fine, but I have not removed the gear that sits just in front of shifter linkage at the base of the foot. I need procedures for removing components, and what to look for in the way of damaged (or bent) parts that would cause the trouble.
