1995 Suzuki 115DT<br />Idle has a backfire thru exhaust about every 6 seconds. The top spark plug coats evenly with a dry carbon coating after a few minutes. I have cleaned all the carbs. Today I took out the idle air screw and spring, and the air jet and recleaned them, and I opened the throttle and sprayed carb cleaner into the idle air jet hole and saw it come out the small hole in the top rear of the carb, so I feel that passage is clear. I also sprayed into the air jet hole and it seemed clear. While idling I lossened the air jet and it speeded up the engine a little, and then even removed it, but it still had the backfire.. I figured that cylinder is running too rich, but I can't find the problem. Has any one encountered this? Joe
