First time user on used early 90's model Suzuki 9.9...<br /><br />From where on the engine does water expel via the water pump?<br /><br />Currently the engine only has a heavy spray coming out of the exhaust hole which is cool to the touch after the engine has had a chance to warm up. But, it does not have a pee stream shooting out the side like I expected to see. Furthermore, I also do not see where it would pee from so I am assuming/hoping that the water is expelled out the back in a spray but wanna make sure I am right before running this engine at great lengths. Should the engine have a pee stream out the side as well?
