I errored when changing the lower unit lube on my Yamaha SWS 150 motor. <br /><br />After filling the lower unit with lube to the fill level, I tightened the top screw and thought I should pump more lube to replace all the air.<br /><br />Too much pressure. The lube began to run out of the small hole next to the water in-take. Did I blow the seal? What next, take it to a mechanic before serious damage?<br /><br />Thanks in advance for any appreciated advise/experience.
