Re: Suzuki DT140 Fuel Primer Bulb
Hi atmunshi,<br />Personally I would start a new post on this (electrical?) problem.<br /><br /> You wrote:<br />The key to the remote control box stopped turning over the engine and would not rotate the starter. <br /><br />Is it a "NA12S" remote control box? (I had a Suzuki DT65, 1991, before with a NA12S)<br /><br /> Inside the control box, a metal piece broke off of the throttle. <br /><br />I guess you can buy spare parts... check with a Suzuki service center.<br /><br /> The boat was unable to start until I manually started it like you would a car with a bad starter. <br /><br />I would check with a Multimeter that You have continuity (ohm) with the various electrical wires in the ignition switch. Could be fault with switch itself or the wires from switch to engine. <br /><br /> When it did get started, it ran in gear (it would not start in neutral). It would not go into neutral at all - even when the control arm was raised straight up vertically!<br /><br />Do You mean the control arm on the outboard (not the arm in the control box)?<br />Try disconnect the gear rod end from geararm on the outboard and then (with battery leads diconnected so the engine can not start by accident) move the geararm with your hand back and forward a little while turning the propeller sligtly clock- and anticlockwise until it "clicks" in neutral. The propeller will turn easy now in any direction and you know it is in neutral. There is also a "neutral start switch" in the control box (at least on NA12S) that maybe has something to do wth the problem. There are some fuses also but I do not know exactly where thay are since I do not have wiring diagram, but I guess it is best to check them also.<br />I suggest You get a Seloc or Clymer manual (does not cost much) that cover Your DT140 (1983) so You can get the wiring diagram etc to help troubleshoot easier.<br /><br />Good luck!<br />/Bo
