Engine info: 1988 DT200 "V" Suzuki Exante (voice alarm modual"<br /><br />Condition:<br />Engine starts and idles fine<br />When Opening the throttle, the RPM stop at 1400<br />Above 1400 the engine acts as if it is starving for fuel or flooding with the timing not advancing.<br /><br />Pump fuel bulb while this is happening and at idle and no effect. Did this to check for fuel pump diaphram problems.<br /><br />Activated the choke during the condition and no change or the engine runs rougher and dies<br /><br />No alarms<br />No Buzzers<br />No lights on the monitor lite (i.e. check engine lite)<br /><br />Ran the engine on aux. fuel tank and same condition exists<br /><br />Ckeck compression 130-135 all cylinders<br />Check spark, good<br /><br />Found that the engine will start in gear<br />And that the emergency stop switch laynard being off has no effect.<br /><br />Any and all advise is welcomed. I have no Suzuki trained service mech. near me.<br /><br />Thanks,<br />DJ
