Crabcake00
- Sep 14, 2003
- 2
How do you adjust the Shift Cable in the Engine?<br />After wrapping a small crab pot around the prop, the shift lever did not work normally. I could not get it in Forward gear. I turned the Shift Cable Shaft in the engine attached to the shift plate and got it to shift normally to get me home, but now it's doing it again. Is there a prcedure to adjust the cable to shift properly without a Hit & Miss approach ?<br />Thanks in advance for your input.<br />Crabcake00
