lostatseawithoutanengine
- Aug 1, 2003
- 1
I have a Suzuki DT65 (1989) which has just been serviced at the Dealers but is still running with a problem that they are unable to solve!<br /><br />'Here goes', the engine runs fine at low speed and sounds sweet and will run continuosly like this, until, when I open up the throttle its great for a few minutes and then it dies and will only run at just over tickover, it still sounds OK maybe a little throaty but I refuses to increase in revs. If I stop the engine and start it again the whole process is repeated but the engine will die much quicker when warm.<br /><br />What i've tried<br /><br />A full engine service by a Suzuki Dealer<br />Checked all fuel line connections for air getting in<br />Pumping the fuel line bulb (nothing happens)<br /><br />The engine is powering a 17ft Dellquay Dory similar to a Boston Whaler Montauk and is fitted with an 11 1/2 pitch prop. <br /><br /> Please Help I,m Desparate, the sun is shining & I cant use the Boat !!!
