Suzuki DT150 Gas Gulper
vinnyp
My first post here, so here goes.<br />Have a Suzuki DT150 EFI on an Angler 204 fiberglass hull. On recent trip, using GPS, clocked the engine running 1hr 57min and traveling 34.73 miles. I had 3 men (approx 550 lbs), 20 gal live bait well full, 40 lbs ice and a full tank of fuel (80 gal). Ran engine 3500 to 4500 rpms. I used the trim tabs to adjust the maximum speed at current rpm to get the greatest fuel efficientcy. But to my dismay when I returned inland and refueled I had burned 23.5 gal of fuel. :( This is almost 12 GPH which seems a bit much I think. Engine starts fine and seems to run okay except for the excessive fuel burning. Any suggestion here would be greatly appreciated. Thanks
Mettaree
Re: Suzuki DT150 Gas Gulper
vjportera: With carrying about 1230# load in the boat and running 4000+ rpm 12 gph isn't bad. At WOT you will probably burn 15+ gph. With 80 gal. fuel at 12gph you've got 6+ hours of running at that speed. Sounds good??? 150's burn a little more than 50's.
gss036
I have always heard the the Suzi likes gas. My friend ran a Suzi Special edition 200 and while I got 12 on my mercury 200, he would burn 14-15 gph on the same trip. <br />Sounds normal to me also.
Fouled Plug
Ensign
Actually, sounds like your fuel consumption for the load you are pushing is right on the money.
lakensea
If unhappy trade it for a DF140 and get 6-8 GPH at those speeds.
vinnyp
Thanks guys,<br />I guess i will just need to fill my pockets BEFORE I fill the tank. :D <br />Would I expect the same performance from a 4 stroke, and if the boat tag says max 185hp could I push to 200hp.
trumpetbucks
4-stroke will give better fuel economy, but don't exceed the boat's rating!<br /><br />Good luck!
