Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Yamaha 115 Lower unit oil change.
  • Yamaha 115 Lower unit oil change.
    Anything special about changing the oil in a Yamaha lower unit. Anyone using synthetic? Directions and opinions would be appreciated.Bill
    Re: Yamaha 115 Lower unit oil change.
    Nothing special just make sure that you replace the gaskets or o rings for the vent & filler plugs. Check your shop manual for details.
    • #3
      it is recommended that you use 90 gear oil.And you refill it through the same hole that you drained out the oil to ensure that no air gets trapped in the unit
