I have a Suzuki 25 HP that will not idle while in the water, unless I repeatedly choke it. Cannot put it into gear--it dies. Everything works perfectly with the ear muffs on--will idle down, can shift into gear.<br /><br />I've adjusted idle speed and air mixture. Why does it work fine on land with a hose, but not in the water? Water pump seems to work.
