Re: Suzuki DT 55 (1986?) Oil injected 55 hp
Man this is weird. I don't know if those cranks come apart on that model or not, somebody here might know, but I don't think it would even run if it was busted. I don't think it would run if it could be installed out of sync. I think you may be on to something with the timing. From your description it sounds like #2 is not firing at the right time. I am not too familiar with the Suzuki ignition even though I have a 1987 DT85 because mine has yet to act up. When you took the flywheel off did you notice anything that was loose or not bolted in its place. Its pretty evident on my DT85 which coils go to which cylinder, how about yours, are you sure the firing order is set up right? I would also look for any cross arcing, maybe one of the other cylinders is arcing over to #2 or vice versa and screwing up the firing order. Try running it in the dark with the cowling off and look for arcs. Keep us posted, I like a good mystery.
