I have a 1992 90hp Yamaha outboard that several years ago was evaluated when the overheat alarm started coming on at 4200rpm and was found to have corrosion in the cooling system. The temp sensor and thermostat checked out and after having the corrosion cleaned out it ran well for 6 months and started overheating again. It has been run regularly without a problem cruising at 3600rpm and the problem has not progressed. It was always flushed, and now I run "salt away" through it. Any other guys had problems with this engine?Any comments about cleaning out corrosion. It was mentioned that possibly the high lyme content in our water could have contributed. Thanks
