I've found out that the onboard flush hose on the Yamaha isn't for flushing the entire engine or meant to be used to run motor to flush internal workings = I've been leaving a lot of salt water inside my motor. Wondering if there is a good cleaner like CLR I can use or CRC rust inhibitor I can spray inside to dissovle/remove any corrosion that's built up on the inside?
