Yamaha 9.9 cooling
AlexR
I've got a second hand Yamaha 9.9 2 stroke (5 years old). Engine runs fine but doesn't have a stream of water coming out of the pee hole/telltale. Instead it breathes out a very fine mist of water. <br /><br />Is this normal? <br /><br />How can I tell whether the cooling system is working ok or not?<br /><br />If it is not normal, how can I tell whether any damage has been done to the cylinder/pistons or not?
Waterbugtoo
Re: Yamaha 9.9 cooling
A fine mist is normal out the exhaust relief. Check the pee hole to make sure its not clogged up. Us a stiff wire to clean it out. Check compression for condition of internals.
rons boat
Feel the head with the engine running and notice if it gets hot to the touch. Those pee holes are home to a lot of spiders. Use a small flexible wire with the engine running to see if you can break up a possible obstruction. Sometimes I use a hay wire hose conversion connected to a garden hose and force water backwards. Rarely on a properly maintained motor is there a thermostat problem. Oh, how long has it been since impeller was changed?
