suzuki 55 running rough after rebuild
Rob.s
I have a 1994 suzuki dt55 which ended up stuffed after a hole corroded through side of head. Ive rebuilt it, rebore,new piston,etc following service manual. started first go but runs really rough, misses.will idol but more throttle= rougher.the bottom carbie ended up with salt water in it, have cleaned it and appears ok. can the timing go out, or even be adjusted at all? all filters etc are ok. thenks
