Re: yamaha 150 oil mixture
Is it that simple???? I have a '85 Yamaha 220 V6 with a remote oil pump (single hose). I am having problems with air bubbles/oil coming right out of my remote oil pump. It's having the same problem that I have read about in this forum. Low oil light comes on about 15-30 minutes into the trip. Pulled off the cowling and the reserve oil tank shows 1/3 full. The only thing that seperates my problem from everyone elses is that when I turn off the engine then turn the key to the on (not start) position, the remote oil pump runs, but it does not pump oil into the reserve tank (on the engine). I've even tried to relocate the oil tank closer to the engine (3'-4'), I would easily replace the pump, but they Yamaha dealer says it about $350.00 (OUCH !!!!). I have not run through ALL of the troubleshooting giude in the Sealoc repair manual, but I am pretty sure it's got someting to do with that pump.<br /><br />I guess I'd better get to a question here. Is it just a matter of disconnecting the oil injection and the alarm to convert the engine to accept a 50:1 mixture? That seems too simple! Why aren't there more posts about this? It would solve many headaches with that damn pump! <br /><br />What are the drawbacks? <br /><br />Saltymut
