Yamaha Enduro Dealer needed in South FL
bibr
I am trying to find parts for two older Yamaha Enduro motors (year unknown), but my local dealer cannot access the records for the motors. I assume since Enduros are not sold in the US, I may need to find a specialist. If it helps, the motors are a 15 HP, serial # 864C-L-368256, and a 40 HP, serial # 6J4-S-010565. Both motors are mid-80s.<br /><br />Thanks for any help!<br /><br />Bob
Bear
Re: Yamaha Enduro Dealer needed in South FL
This is what I found:<br />6J4 1984- 40JM<br /><br />Nothing on the 15HP, just this:<br />662 1974- ENDURO 15A<br />669 1974- ENDURO 15AK/15FK <br /><br />Is there a letter in the lower left or lower right corner? Where the red arrrow points. The letter can be very hard to read. <br /><br />If so, follow this link for mfg year:<br /> http://www.marinshopen.se/guide/yamguide.htm <br /><br />
yambokst.htm
bibr
Model on the 15 HP is "15D", problem is when my dealer goes into his computer for parts, he says nothing comes up. I am looking for a carbeurator for the 40HP, and I need an overhaul kit for the 15 HP (I guess at 28 years, it mights be time).<br /><br />Thanks, Bear!
bibr
Bear-<br /> Do you know if Yamaha sells a rebuild kit (pistons, rings, seals, etc.) or if I need to buy each item individually?<br /><br />Bob
