seized 40 hp Suzuki
richardsondm
After about 20 minutes of running, from idle to 2/3 throttle, my outboard motor seized up. No funny noises prior to seizing, nothing unusual that I can see externally.<br /><br />I'm not sure what year the motor is, but the model nuber is DT 40, identification number is 506421.<br /><br />Any ideas on how to start diagnosing the problem?<br /><br />Thanks!
Hooty
Re: seized 40 hp Suzuki
Piston seizing is usually caused by lack of lubrication. Will it turn with a wrench on the flywheel and the plugs out?<br /><br />c/6<br /><br />Hooty
richardsondm
I pulled the plugs, they are brown and dry. The fly wheel turns about 1/2 turn with moderate friction, and then stops dead. It will back up, but then stops at the same spot.<br /><br />The engine is oil injected, I did not get any warnings (alarm) that it was not functioning, and the oil reservoir is full.<br /><br />Thanks!<br /><br />GatorDave
lakensea
Pull the lower unit and try turning the engine. You may have fried the gearbox.
richardsondm
The prop turns freely in neutral, but does not turn when I put it in gear. If the gear box was damaged, wouldn't the prop fail to turn whether in neutral or in gear?<br /><br />GatorDave
