• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
40 hp yamaha electric problem
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 40 hp yamaha electric problem
    1998 Yam wont start or tilt, batt. is strong and with key on shows no volts on meter on the console.I can jumper across the starter relay and it will start with no problem.At idel the volts will come back up after about 40 sec. as well as the trim starts to work, but at 3/4 throttle I lose Vs. & trim and will not start if I turn it off.I checked main harness conection & key switch for loose or corroded wires .the key is on the console. HELP!
    Re: 40 hp yamaha electric problem
    check your ground on the engine and move the harness where it goes into the engine while soome one is trying to start it it may have a broken wire in the harnes
    • #3
      I finaly got a shop manual with a wire diagram. but I had tried moveing the harness before with no luck ,I watched the volt meter for a reading.Now I am going to ring out the harness per the manual tomorow.I reply soon and say how it went. thanks !
      • #4
        I found an open in the inline fuse holder base.
