I have a 89 Yamaha 115 outboard that has been used in the saltwater since 1989.<br /><br />I need to know about the shift linkage that feeds from the L.U. to the upper section.<br /><br />I have observed, what I assume is the linkage shaft, that is exposed to the environment in the upper unit. The salt air has taken its toll and this piece has rusted almost half away. My concern of course is that the shaft rotates and this is the weak link, since I like to travel off shore, this is a concern.<br /><br />Help in the removal of this piece is greatly appreciated. Also, is this shaft directly to the upper unit, welded to the shift plate or there an easy access, or does this piece couple into another shaft further up.<br /><br />Help!<br /><br />Thanks<br /><br />P.S.<br /><br />Just finished reading all of the other posts and came across a similar situation where someone recommended using a "shaft sleeve" held in place by loctite.<br /><br />I would appreciate your feedback and any info someone might have on this item. It could save me a lot of headaches if this is a good fix.<br /><br />Thanks!
