Yamaha 40HP Model and year?
Boat_Boy!
I have recently inherited a small boat with a Yamaha 40 hp putboard on it. The motor is a 2 cylinder with two carbs. Does anyone know what the correct fuel oil mixture for this engine might be? I'm afraid to try and start it without these details. <br /><br />It's model number is C40ELRQ and there's an additional code (date code mayber?) of 6E9 on the tag. Serial number is 55276.<br /><br />Any info on this motor would be greatly appreciated.<br /><br />NB I ahve been waiting for four days for Yamaha Canada to call me back!<br /><br /><br />------------------<br />Boat_Boy!
fone_man
Re: Yamaha 40HP Model and year?
C40EL... or 40C EL<br /><br />Yamaha built the Mariner engines-Japanese Models<br /><br />Using both codes with Mariner/Yamaha, I have come up with 1980-1981 Model year.<br /><br />Closer than you were before... I will keep looking<br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
Boat_Boy!
It is definately a C40, but I know that it's not that old, I think it's between 1990 and 1993, just by trying to recall when my grandfather bought it.<br /><br />By the way, I have gone to three different dealers and they have given me three different answers to this question!<br /><br />------------------<br />Boat_Boy!
fone_man
here you go again....<br /><br />40FM/40FE/40FEML 6E9 1981-1983<br /><br />40CM (40CE/40CEM) 699 1979-1982<br /><br />Using the numbers you provided, these are the years of production of these models from the information I have... Best of luck on your quest.<br /><br /><br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
fone_man
All 40 HP's:<br /><br />40AM/40AE/40AEM 676 1977-1979<br /><br />40B (JET-PROP) 679 1977-1979<br /><br />40CM (40CE/40CEM) 699 1979-1982<br /><br />40DM (40DE/40DEM) 6A0 1979-1982<br /><br />40FM/40FE/40FEML 6E9 1981-1983<br /><br />40G 6F6 1982-<br /><br />40GMK 6F5 1982-<br /><br />40H/40V 6H4 1983-<br /><br />40JK (JPN) 6H9 1983-<br /><br />40JM 6J4 1984-<br /><br />40QM/QE 6R6 1990-<br /><br />40VE/VEO/VEMHO 63C 1995-<br /><br />40VETO/VEMHDO 63D 1995-<br /><br />40VMH/VMHO/VRO 63B 1995-<br /><br />Take your pick..........<br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
Boat_Boy!
fone_man,<br /><br />Thanks for all your help. Guess what! Yamaha Canada just called me back. They say this thing is a 1992 C40. The model number is C40ELRQ.<br /><br />The E is for electric start, manual tilt, L for 20" leg, R for remote control, Q indicates model year of 1992. They say the serial number matches correctly to this data. They say the mix ratio is 100:1. This sounds really low to me. Could they be right on all the above? It is electric start, manual tilt, remote controlled and has a 20" leg...<br /><br />Thanks for all your help.<br /><br /><br />------------------<br />Boat_Boy!
fone_man
I am just going with info I had... It would be safe to assume that "Yamaha Canada" would be correct...<br /><br />Do you have number that you used to contact... I would luv to have it. Thanks.<br /><br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
Boat_Boy!
Yamaha Canada's customer service number is 416-498-1911. They take a LONG time to get back to you. The USA number is 714-761-7300.<br /><br /><br /><br />------------------<br />Boat_Boy!
