Re: Suzuki stalling
Howdy, Will. Welcome to the best board on the net.<br /><br />When you cleaned the carb, what did you do? Did you dismantle it and run wire or air through every passage, no matter how small?<br /><br />Your symptoms are those of a plugged up high speed jet.<br /><br />Less likely possibilities are other fuel starvation causes, such as a low float setting in the carb, plugged tank vent, air leak in hoses, bad primer bulb, plugged up fuel filter or failing fuel pump.<br /><br />You can verify that it is a fuel problem by spraying a bit of fuel mix from a spray bottle into the carb throat when you open up the throttle. If she takes off for a moment it is a fuel problem.<br /><br />Good luck.<br /><br />Red sky at night. . .<br />JB
