barryUS490
- May 19, 2009
- 6
I need to replace the o-rings in the trim unit due to leakage. I have removed the unit from the engine and was able to remove the cylinder end cap but the piston will not pull out?
Does the piston top need to be unscrewed before it can be removed from the cylinder or do I need to use more force to remove the piston/rod?
Thanks....
Thanks....
