ianyoung77
- Mar 28, 2005
- 121
I've got a 2003 DF140 and the oil cooler let go draining the oil and alarming. After I worked out the problem I changed the cooler and oil and it idled OK so I took it for a low rev spin. After about 10 min I got a knocking noise and stopped the motor. Changed the oil which was milky. Still has a knocking noise.
The compression test is ok. Oil is not leaking. Removing spark plugs individually makes no difference. Removed lower case and noise disappeared. I'm thinking a bearing - any ideas which one? Could still be some water in the oil. Could this cause the noise? Any ideas what to try next?
