The oil/cooling alarm came on on my 70hp today and engine would go intermittently into safe mode and alarm would not cut off. Motor eventually came out of safe mode but alarm remained on back to marina. Trailered boat home over an hour and alarm would still turn on when key was turned with motor hooked up to hose. Motor has a strong stream, removed cowling while running and motor was not hot, oil reservoir level was good. I have had the alarm come on occasionally during the winter while duck hunting for a minute or so but once motor warmed up it turned off and wouldnt come back on. Any ideas as to what could be the issue or how to determine if its an oil issue or cooling issue. Thanks
