Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
25hp manual starter problem
  • 25hp manual starter problem
    I had to replace the pull rope and pawl spring on my starter. When I tighten down the center bolt the sheave will not turn and if I loosen it the pawl will not work.
    ​Looking for any ideas on to fix. I am at a loss at this point.
    Hard to tell with out seeing it put together. Did you keep track of all the parts taking it apart? Had it been working before? It should have some washers between the rotor and the bolt.
    • #3
      Also check the top of the starter plate to see if it's rubbing or if it's the bolt pressure.
