(Im writing in behalf of my father, please excuse any inaccurate wording)
I have a Yamaha 225TXRQ engine which connects to a 703 (10 pin) side mount remote control box. The engine seems to work fine when started directly from inside the engine (choke valve A and B). However it does not work when I push in and turn the ignition key. This only happens when the engine is cold.
When the engine is hot I am able to start it by pushing in and turning the key. I suspect the problem may be somewhere in the prime starter/choke wire?
Please help, I will be happy to provide any additional information needed.
Thank you.
Thank you.
