My mechanic is almost at a loss. It 2006 50HP model 50TLR 2 stroke.
It starts fine and run fine at low RPM. It can rev up at neutral to high RPM levels. BUt when we put it at forward it stays at low RPM even at WOT.
Compresson is at 120 on all 3 cylinders
Spark plugs are new
Fuel pump OK
Impeller new. Water pump runs good.
Coil was checked
Oil level in the tank is at maximum.
It's not overheating.
I read some similar post as my situation but I think it might be different because of the high RPM can be reached at neutral.
Sorry, don't have a tachometer to give you a real RPM value.
With this RPM, it runs like a 15hp instead of 50hp.
Does it sounds like a overheating sensor problem?
Thanks in advance
Spark plugs are new
Fuel pump OK
Coil was checked
Thanks in advance
