Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
1982 dt40 clicking noise
  • 1982 dt40 clicking noise
    I actually rebuilt the pontoon the motor is attached to and now in the process of putting it back together.
    I had to remove the throttle controls because I rebuilt the captains console. I took videos and pictures of how the harness was hooked up but I'm not sure I got them hooked up correctly. I say that because before I took it all apart I could turn the key and the motor would turn over but now all I hear is a clicking by the starter. Is this a battery issue/ connection or is this wiring?
    I only have the positive and negative wires that come out of the motor hooked up. I believe the other wires are for the lights and horn. All of that wiring is trash so I didn't bother hooking it back up.
    Any help would be appreciated.
    Not an expert but I'd say either the connections aren't tight enough or the battery needs a good charge. Can you eliminate the battery as the issue and try a different one?
    Dang - I cut it three times and it's still too short!!...
    2004 Scout Dorado 175 Dual Console
    Yamaha 90 4-Stroke
    • #3
      I'm trying to find some new cable ends from the motor to the battery. There are some wires that are broke at the terminal ends.
      I took the same battery and put it on my 70 evinrude and it starts like a champ.
      • #4
        I replaced the cable ends and it still just clicks. Hmmm
        • #5
          So the clicking noise is from the solenoid. How do I test the solenoid?
          I did run hot a hot wire from the positive terminal on the battery to the positive end on the starter and the started did nothing. I would think if the starter is good it would at least try to engage, correct? Also the battery is charged enough to crank over my 70 evinrude with no problems.
          • #6
            Does anyone know how to pull the starter apart? It had water in it and it's probably toast. I just don't have the extra right now to buy a new one. I would like to try and clean it up.
            • #7
              I figured it out with the help from another site. Starter is shot.
