I have a 1992 suzuki dt6....and it just stalls when I try to put it towards 'slow' in neutral. Will work fine on high RPM's in forward and reverse. But the reason I wrote here is that when thd rpm's are high it automaticly jumps into forward gear. It will go in reverse but doesn't slips in reverse (which is hiw it suppise to be..not suppose to slip on its own in any gear until manually done so). It gives a sudden jolt to boat and somebody can fall in the water if not paying attention. If sonebody can direct me a tad bit, I can prolly fix it.....I do have Seloc manual but its not the very best manual. I will appreciate help.
Thnx
Raj
Thnx
Raj
